Tagged: 17, General, mechanical-apdl, modeling-and-meshing, structural-mechanics
March 17, 2023 at 9:00 am
FAQParticipantThe /CONFIG command has an argument which will prevent the results from being written to the database after solution. /CONFIG docu: NOELDB — Option to write or not write results into the database after a solution. When VALUE = 0 (default), write results into the database. When VALUE = 1, do not write results into the database. So, the proper command to use would be /CONFIG,NOELDB,1
