March 17, 2023 at 1:11 pm
SolutionParticipantThe UDF in this solution assumes the use of either the standard electric field model or a user supplied magnetic field. Particles are “charged” randomly by setting a DPM Scalar value to represent the number of electrons. The force is applied using the DPM_BODY_FORCE UDF as the force is not applied directly by the fluid as with DPM DRAG.
1. 2055111.zip
- ANSYS Fluent – Eulerian & Mixture Multiphase Models & Applications – Tips and Tricks
- Solver message during DPM calculation: “number of stepsize underflows during particle integration step is x”. What does it mean and how to get rid of it?
- What is the difference between the VOF model and the Eulerian model?
- ANSYS Fluent: Efficient Modeling of Spray Breakup using VOF-to-DPM Transition
- Guidelines for Courant Number for steady and transient simulation.
- Mixing Tank Modeling in ANSYS Fluent
- What is the meaning of VOF courant number and Global courant number in ANSYS Fluent Multiphase Model and how are they related?
- What is the superficial velocity in multiphase flows?
- How do I use porous media in a multiphase flow?
- ANSYS Fluent: Describing Cavitation in a Centrifugal Pump
