June 5, 2023 at 7:06 am
FAQParticipantIn the license file(s), edit the SERVER line and add “PORT=xxxxx”. For example; if you want the ansyslmd to use port 51584 the new SERVER line will look like this: SERVER machine1 DISK_SERIAL_NUM=914324456 1055 VENDOR ansyslmd PORT=51584
