Postprocessing
Postprocessing
How do I get experimental data into CFD-Post?
    • FAQFAQ
      Participant
      There are several ways to import user data into CFD-Post. Data can be imported as line or surface data:
      1. File > Import > Import Surface or Line Data and select the file, or :
      2. Insert > Location > User Surface
      Specify a name and select the file. The data formats are of the form:
      [Name]
      Experimental Data Set 1
      [Data]
      Node No., X[m], Y[m], Z[m], Press.[Pa], Vel.[m/s], Temp.[R]
      0, -0.3, -0.3, -1.0, 0.0, 1.0, 0.224,
      1, -1.0, -1.0, 1.0, 1.0, 2.0, 1.35987,
      2, -1.0, 1.0, 1.0, 1.0, 3.0, -0.45,
      3, -0.3, 0.3, -1.0, 0.0, 4.0, -5.82,
      4, 0.3, -0.3, -1.0, 2.0, 5.0, 9.6323,
      5, 1.0, -1.0, 1.0, 3.0, 6.0, 7.1859,
      6, 1.0, 1.0, 1.0, 3.0, 7.0, -4.656234,
      7, 0.3, 0.3, -1.0, 2.0, 8.0, 2.1237,
      8, 0.0, 0.0, 2.0, 5.0, 9.0, 6.456,
      [Faces] # Faces are defined by their points, represented by the point IDs: 3 points for a tri-face and 4 points for a quad-face. The face normal is defined by the order of the points, so define all points in either a clockwise or counterclockwise direction to obtain a uniform face normal.
      Note 1: Normally the first 3 variables will be X, Y and Z – i.e we are assuming 3D data.
      Note 2: There is no explicit limit on the number of variables.
      Note 3: Units are optional and can be omitted or specified as []
