May 25, 2023 at 7:30 am
SolutionParticipantWhen a parametric or optimization calculation has a lot of calculation points then it is suggested to use LS-DSO for run the calculation (not DSO). After lunch the calculation the user needs to extract the results, do post-processing. This solution explains how to do it. Keywords: Maxwell, speed up, parametrics, parametrization, optimization, DSO, LS-DSO, LSDSO, post-processing, results. Please refer to the attachments to access the Solution.
1. EM_FAQ_How%20do%20I%20extract%20results%20%28post-processing%29%20a%20LS-DSO%20calculation%20in%20Maxwell.pdf
2. Post_Processing_LSDSO.pdf
- Cloud Computing from Electronics Desktop
- How to enable GPU acceleration in Electronics Desktop?
- How to import/export an Ansys Maxwell model in Workbench?
- How to fix messed up Windows layout?
- What are the available boundary conditions in Maxwell?
- How do I calculate inductance and resistance of a coil in post-processing phase?
- Electric Motor Design Using Ansys Motor-CAD – Part 1
- How to create and manage a queue of simulations?
- ANSYS Electronics Desktop: Simple Communications Channel For Signal Integrity Analyses – Part III
