- All Categories
- Fluids - Postprocessing
- How do I display a vector or contour and the mesh lines together via TUI command?
Tagged: ansys-fluent, Display contour, Display grid, Display vector, tui
June 6, 2022 at 8:33 am
FAQParticipantIn Fluent, the TUI command required to display the grid along with the vector and contour display is:
/display/set/render-mesh yes
Example: Command to display wall1 and wall2 along with velocity contour at z = 1:
/display/set-window 1
to open Window1
/display/ set/mesh-surfaces wall1 wall2 ()
to display mesh outline of wall1 and wall2
/display/set/contours surfaces z=1 ()
to select the surface where you want to display the contour(z = 1)
to display mesh
/display/contour/velocity-magnitude 0 1
to display the velocity contours (range 0-1) on the surface (z = 1)
- ANSYS Fluent: Scene and Animation Creation
- ANSYS EnSight: Overview of Postprocessing a Fluent Case in EnSight
- ANSYS Fluent: Simulation of a Rotating Propeller – Part 2
- Display Multiple Plots in the Same Scene using Overlays in Fluent
- Use Different Modes for Saving Pictures in Fluent
- Creating a User Surface in ANSYS CFD Post-processing
- How can I hide the legend or colormap for a Fluent plot?
- Add Annotation to Graphics Display within Fluent
- How do I automatically export figures generated in CFD-Post from Workbench?
