Tagged: 16, fluent, fluid-dynamics, Modeling/Setup Advice, Reactions, species, Species/Reactions
January 25, 2023 at 7:17 am
FAQParticipantFirst, mark the cells with a species mass fraction INSIDE of ISO-MIN and ISO-MAX under ADAPT>ISO-VALUE ADAPTION. Then, split the register in the fluid zone under Mesh->Separate->Cells. Calculate the volume of the resulting new fluid zone under Report->Volume Integrals->Volume. If the split operation fails or you have a number of fluid zones, do the following: 1.Define a custom field function that calculates cell volume 2.Define a UDS 3.Patch the UDS in the register with the custom field function 4.Calculate the volume of the register by Volume Integral->Sum of UDS in the whole fluid zone
- How do I model humidity in Fluent?
- Configuring and Solving the Chemical Species Transport in Fluent
- ANSYS Fluent: Describing Non-premixed Combustion using the Steady Flamelet Model
- ANSYS Internal Combustion Engine (ICE): Port Flow Part 1 – Getting Started
- Model setup: Setting up chemical reactions
- How do I use the Flamelet Generated Model?
- How can volume fraction be plotted in a species transport simulation?
- ANSYS Chemkin-Pro: Reducing a Combustion Mechanism
- I am running an electrochemistry simulation in Fluent. How can I access the electrochemistry reaction rates with UDF?
- Explanations on the warning Maximum / Minimum PDF table enthalpy exceeded in xxx cells (Non-Premixed or Partially-Premixed models)
