How do I create a linear temperature distribution on an area when I know the temperature on two lines?
Tagged: 17, General, mechanical-apdl, structural-mechanics, thermal
March 17, 2023 at 9:00 am
FAQ
ParticipantYou can apply the temperature as a function of coordinates using tables or functions. However, a simple way is to just switch to thermal elements and apply the temperatures in a thermal analysis. This will produce the linear distribution, and those results can be imported into a structural analysis using LDREAD.
