- All Categories
- Fluids - Postprocessing
- How do I autosave cdat (CFD Post) files from Fluent during a transient simulation?
June 6, 2022 at 8:33 am
FAQParticipantIf we combine a TUI command with Fluent’s Execute Commands we can write out files at specified intervals. The exact command will vary slightly with models, surface labels etc so work through to get the exact syntax.
An example is:
/file/export-to-cfd-post filename_%t surface list () property list () no yes no
The surface list needs each label in ” ” marks, and using * instead should pick all surfaces and volumes.
Note, %t will append the time step (%f is flow time) and () round-brackets terminates a list. Usingwhen in a new menu level will cause Fluent to list all available options at that level, while q (Q) takes you back up one level. The command should then added to the Execute Commands under Calculation Activities and set to trigger every some time steps.
- ANSYS Fluent: Scene and Animation Creation
- ANSYS EnSight: Overview of Postprocessing a Fluent Case in EnSight
- ANSYS Fluent: Simulation of a Rotating Propeller – Part 2
- Display Multiple Plots in the Same Scene using Overlays in Fluent
- Use Different Modes for Saving Pictures in Fluent
- Creating a User Surface in ANSYS CFD Post-processing
- How can I hide the legend or colormap for a Fluent plot?
- Add Annotation to Graphics Display within Fluent
- How do I automatically export figures generated in CFD-Post from Workbench?
- How do I display a vector or contour and the mesh lines together via TUI command?
