- All Categories
- Fluids - Postprocessing
- How do I automatically export figures generated in CFD-Post from Workbench?
June 6, 2022 at 8:33 am
FAQParticipantIn the course of running a Design Exploration type analysis in Workbench, sometimes you may want to export figures containing a report of the results without needing to save the result files or interrupt the run. This can be accomplished using the following steps:
1) Create your Workflow (Geometry > Mesh > Solver > Result)
2) Define the required Input and Output parameters
3) Define a dummy Output parameter in CFD-Post
4) In CFD-Post, under Report, deselect all features and enable only the figures to be exported
5) In Workbench, go to the properties of Results container and enable “Publish Report”
6) Define some design points with various values for the input parameters
7) Update design points The pictures are then saved in the project under ~yourproject_filesreport_files.
Note: The most important step is to define the dummy output parameter in CFD-Post. Otherwise the figures won’t be exported.
- ANSYS Fluent: Scene and Animation Creation
- ANSYS EnSight: Overview of Postprocessing a Fluent Case in EnSight
- ANSYS Fluent: Simulation of a Rotating Propeller – Part 2
- Display Multiple Plots in the Same Scene using Overlays in Fluent
- Use Different Modes for Saving Pictures in Fluent
- Creating a User Surface in ANSYS CFD Post-processing
- How can I hide the legend or colormap for a Fluent plot?
- Add Annotation to Graphics Display within Fluent
- How do I display a vector or contour and the mesh lines together via TUI command?
