June 5, 2023 at 7:05 am
FAQParticipantFor applying non-cyclic load like Gravity/Acceleration to cyclic symmetry model, you can use ACEL command under command snippet in WB Mechanical. The ACEL command applies liner acceleration in Global Cartesian CS. The command can be as follows; ACEL,0,9.81,0 !! Consider the axial direction along Z-axis
