How could the particle diameter distribution calculated from the ANSYS CFX solver be analytically verified?
August 25, 2023 at 12:15 pm
SolutionParticipantParticle diameter distribution from ANSYS CFX can be visualized using two methods: 1.) Particle Histograms: Detailed information about the definition of the particles histograms can be found in the ANSYS Help: ANSYS Documentation/CFX/CFX/Pre User’s Guide/Output Control/User Interface/Particles Tab/Particle Histogram. 2.) Setting the Expert Parameter “pt histo = t ” Using the Expert Parameter produces an additional output to the ANSYS CFX Outfile (.out) and its syntax is shown in the attached file histo.ccl. The file can be used when starting the ANSYS CFX Solver with the option -ccl histo.ccl. The method is restricted to Number of Particles and Mass Flow Rate as function of Particle Diameter. An example for setup of Rosin Rammler particle distribution and comparison of the numerical and analytical calculation for the cumulative particle mass fraction/mass flow rate for both methods is attached. Additional keywords: Visualisation
1. 2039795.zip
- Solver message during DPM calculation: “number of stepsize underflows during particle integration step is x”. What does it mean and how to get rid of it?
- ANSYS Fluent – Eulerian & Mixture Multiphase Models & Applications – Tips and Tricks
- What is the difference between the VOF model and the Eulerian model?
- ANSYS Fluent: Efficient Modeling of Spray Breakup using VOF-to-DPM Transition
- Mixing Tank Modeling in ANSYS Fluent
- What is the superficial velocity in multiphase flows?
- What is the meaning of VOF courant number and Global courant number in ANSYS Fluent Multiphase Model and how are they related?
- Guidelines for Courant Number for steady and transient simulation.
- How do I use porous media in a multiphase flow?
- ANSYS Fluent: Describing Cavitation in a Centrifugal Pump
