Tagged: 18.2, contact, General, mechanical, structural-and-thermal, structural-mechanics
June 5, 2023 at 7:05 am
FAQParticipantHigher contact stiffness gives less penetration which in turn gives better accuracy. But higher contact stiffness is also reflected in global coefficients matrix. Higher coefficients make the matrix more ill-conditioned. A PCG solver is sensitive to the ill-conditioned matrices. Thus it will need more iterations which in turn creates longer solution time.
