April 5, 2023 at 2:32 pm
FAQ
ParticipantThe fluid level is not a variable. One needs to use other available variable to detect the position of the free surface. A good indicator is a gradient of density or volume fraction. This gradient will have its maximum at the surface level. Therefore, define a line at the location of interest, parallel to the gravity vector (i.e. perpendicular to the fluid surface). To visualize the location of the surface, create a chart with the ordinate displaying Density.Gradient. Its maximum will be at the free surface.
- Solver message during DPM calculation: “number of stepsize underflows during particle integration step is x”. What does it mean and how to get rid of it?
- ANSYS Fluent – Eulerian & Mixture Multiphase Models & Applications – Tips and Tricks
- What is the difference between the VOF model and the Eulerian model?
- ANSYS Fluent: Efficient Modeling of Spray Breakup using VOF-to-DPM Transition
- Mixing Tank Modeling in ANSYS Fluent
- What is the superficial velocity in multiphase flows?
- Hydrodynamics and Wave Impact Analysis
- ANSYS Fluent: Describing Cavitation in a Centrifugal Pump
- How do I use porous media in a multiphase flow?
- What is the meaning of VOF courant number and Global courant number in ANSYS Fluent Multiphase Model and how are they related?
