Tagged: 2019 R3, General, mechanical, structural-mechanics
March 17, 2023 at 9:00 am
FAQParticipantIn Engineering Data, you can define some Orthotropic Stress Limits. These can only be post processed via the command PLESOL, FAIL, SMAX in a command object under the solution branch. Also, refer to FC, TB and TBDATA commands that would be written to the ds.dat file after the limits are defined in Engineering Data.
