Tagged: 2019 R1, autodyn, parallel, structural-mechanics
April 13, 2023 at 7:33 am
SolutionParticipantPlease find attached document to setup autodyn parallel environment for running a problem using autodynwrapper
1. AUTODYN_parallel_setup_using_AUTODYNWRAPPER.pdf
