How can we interpret the exchange term Kq from the momentum equation within the framework of multiphase porous media?
Tagged: 19, fluent, fluid-dynamics, MP - Eulerian MP Flow, porous-media
April 5, 2023 at 2:32 pm
FAQParticipantThe term Kq is an effective permeability and is computed as a product of the relative permeability, which depends on the saturation of the wetting and non-wetting phases, and absolute (or intrinsic) permeability which relies on the properties of the porous medium.
- ANSYS Fluent – Eulerian & Mixture Multiphase Models & Applications – Tips and Tricks
- Solver message during DPM calculation: “number of stepsize underflows during particle integration step is x”. What does it mean and how to get rid of it?
- What is the difference between the VOF model and the Eulerian model?
- ANSYS Fluent: Efficient Modeling of Spray Breakup using VOF-to-DPM Transition
- Guidelines for Courant Number for steady and transient simulation.
- Mixing Tank Modeling in ANSYS Fluent
- What is the meaning of VOF courant number and Global courant number in ANSYS Fluent Multiphase Model and how are they related?
- What is the superficial velocity in multiphase flows?
- How do I use porous media in a multiphase flow?
- ANSYS Fluent: Describing Cavitation in a Centrifugal Pump
