January 25, 2023 at 7:17 am
FAQParticipantMass fraction of phase-i can be evaluated using the following expression via custom-field-function: mass fraction of phase-i = (phase-i volume fraction)*(phase-i density)/(mixture-density) … Eq. (1) where mixture-density is another predefined custom-field-function as mixture-density = sum of [(phase-i volume fraction)*(phase-i density)] for all the phases “i” in the domain For example, in a two-phase simulation: mixture-density = (phase-1 volume fraction * phase-1 density) + (phase-2 volume fraction * phase-2 density) mass fraction of phase-2 = (phase-2 volume fraction)*(phase-2 density)/(mixture-density) Note: To evaluate the average mass fraction of a phase across a flow boundary, it can be obtained using: mass fraction of phase-i = (mass flow rate of phase-i/mixture mass flow rate) … Eq. (2) At a flow boundary, the mass-weighted average of the mass fraction values obtained using Eq.(1) will be nearly equal to that obtained using Eq.(2) if the interphase slip is negligible.
- ANSYS Fluent – Eulerian & Mixture Multiphase Models & Applications – Tips and Tricks
- Solver message during DPM calculation: “number of stepsize underflows during particle integration step is x”. What does it mean and how to get rid of it?
- What is the difference between the VOF model and the Eulerian model?
- ANSYS Fluent: Efficient Modeling of Spray Breakup using VOF-to-DPM Transition
- Guidelines for Courant Number for steady and transient simulation.
- Mixing Tank Modeling in ANSYS Fluent
- What is the meaning of VOF courant number and Global courant number in ANSYS Fluent Multiphase Model and how are they related?
- How do I use porous media in a multiphase flow?
- What is the superficial velocity in multiphase flows?
- ANSYS Fluent: Describing Cavitation in a Centrifugal Pump
