Tagged: 2019 R1, fluent, fluid-dynamics, MP - Eulerian MP Flow, multiphase, phase-change
March 17, 2023 at 1:11 pm
SolutionParticipantIn a multiphase simulation, where one of the mass transfer mechanisms is employed, such as – Cavitation – Evaporation-condensation (Lee Model/Thermal Phase Change) – Species-mass-transfer – Boiling Mass transfer rate can be reported using “Volume Reports” Select report type as “Volume Integral” Select field variable as “Phase Interaction…” Select the appropriate mechanism, which are listed as “Mass Transfer Rate 1”, “Mass Transfer Rate 2” and so on. The mechanism number in this list would be as per the order/number of mass transfer mechanisms invoked in the Phase Interaction panel. This would report the mass transfer rate in [kg/s]. Please refer to the attached document for a snapshot of this report panel.
1. 2058148.pdf
- ANSYS Fluent – Eulerian & Mixture Multiphase Models & Applications – Tips and Tricks
- Solver message during DPM calculation: “number of stepsize underflows during particle integration step is x”. What does it mean and how to get rid of it?
- What is the difference between the VOF model and the Eulerian model?
- ANSYS Fluent: Efficient Modeling of Spray Breakup using VOF-to-DPM Transition
- Guidelines for Courant Number for steady and transient simulation.
- Mixing Tank Modeling in ANSYS Fluent
- What is the meaning of VOF courant number and Global courant number in ANSYS Fluent Multiphase Model and how are they related?
- How do I use porous media in a multiphase flow?
- What is the superficial velocity in multiphase flows?
- ANSYS Fluent: Describing Cavitation in a Centrifugal Pump
