How can I write DPM Sample files on post processing surfaces such as iso-surfaces created within Fluent?
Tagged: 19, fluent, fluid-dynamics, MP - Particle Tracking, post-processing
April 5, 2023 at 2:32 pm
FAQParticipantIn a few instances it is desired to write DPM sample files passing through a certain post processing surface such as iso-surfaces created within a Fluent session. However, such surfaces are not available to choose while writing DPM sample files via Report -> Discrete Phase -> Sample option. The workaround is to create planes from the iso surfaces which can be used for writing dpm files. (Note that this only works with planar iso surfaces at this point)
- Solver message during DPM calculation: “number of stepsize underflows during particle integration step is x”. What does it mean and how to get rid of it?
- ANSYS Fluent – Eulerian & Mixture Multiphase Models & Applications – Tips and Tricks
- What is the difference between the VOF model and the Eulerian model?
- ANSYS Fluent: Efficient Modeling of Spray Breakup using VOF-to-DPM Transition
- Mixing Tank Modeling in ANSYS Fluent
- What is the superficial velocity in multiphase flows?
- What is the meaning of VOF courant number and Global courant number in ANSYS Fluent Multiphase Model and how are they related?
- Guidelines for Courant Number for steady and transient simulation.
- How do I use porous media in a multiphase flow?
- ANSYS Fluent: Describing Cavitation in a Centrifugal Pump
