June 5, 2023 at 7:04 amFAQParticipant
Two APIs can be used to detect analysis type in Mechanical: ExtAPI.DataModel.GeoData.Assemblies[0].Dimension ExtAPI.DataModel.Project.Model.Geometry.Model2DBehavior You can use the first to see if it is a 3D or 2D analysis, and if 2D, you can use the second to see the type (Plane Stress, Plane Strain, Axisymmetric). Note that even if it’s a 3D analysis, the second command will return a value (Plane Stress).
- The LS-DYNA equivalent of *MODEL_CHANGE card (in ABAQUS). Which keywords can be used to introduce(activate)/delete(deactivate) elements in the middle of a calculation (at user-specific time/load steps).
- How to resolve “Error: Invalid Geometry”?
- After Workbench crashes, how can I recover the project from a .mechdb file?
- Model has a large number of contacts – how to reduce them?
