Tagged: 18.2, fluent, fluid-dynamics, Modeling/Setup Advice, Reactions, species, Species/Reactions
January 25, 2023 at 7:17 am
FAQParticipantThe easiest way is to select the Eddy dissipation option and increase the A coefficient by 2-3 orders of magnitude. This multiplies the reaction rate, so if it is large enough, the reactants will react quickly even if the turbulent conditions would not normally allow instantaneous reaction.
- How do I model humidity in Fluent?
- Configuring and Solving the Chemical Species Transport in Fluent
- ANSYS Fluent: Describing Non-premixed Combustion using the Steady Flamelet Model
- ANSYS Internal Combustion Engine (ICE): Port Flow Part 1 – Getting Started
- Model setup: Setting up chemical reactions
- How do I use the Flamelet Generated Model?
- How can volume fraction be plotted in a species transport simulation?
- ANSYS Chemkin-Pro: Reducing a Combustion Mechanism
- I am running an electrochemistry simulation in Fluent. How can I access the electrochemistry reaction rates with UDF?
- Explanations on the warning Maximum / Minimum PDF table enthalpy exceeded in xxx cells (Non-Premixed or Partially-Premixed models)
