Tagged: 19, cfx, fluid-dynamics, MP - Particle Tracking, multiphase, transient
March 17, 2023 at 8:59 am
FAQParticipantThe particle source term data and current particle positions from the initial values file are used, if you follow the instructions below: GUI: ANSYS CFX Solver Manager ->Define Run>Initial Values Tab: Activate: Continue History from Continue History from: Initial Values File Use Mesh from: Solver Input File Command Line: Use one of the following options on the command line: -continue-from-file
-cont-from-file Use initial values and continue the run history from the specified ANSYS CFX Results File. The mesh from the Solver Input File is used unless the -use-mesh-from-iv option is also specified. Key Words: Lagrangian Particle Tracking, Lagrange Particle Tracking, transient, restart, modified mesh, changed mesh
- Solver message during DPM calculation: “number of stepsize underflows during particle integration step is x”. What does it mean and how to get rid of it?
- ANSYS Fluent – Eulerian & Mixture Multiphase Models & Applications – Tips and Tricks
- What is the difference between the VOF model and the Eulerian model?
- ANSYS Fluent: Efficient Modeling of Spray Breakup using VOF-to-DPM Transition
- Mixing Tank Modeling in ANSYS Fluent
- What is the superficial velocity in multiphase flows?
- What is the meaning of VOF courant number and Global courant number in ANSYS Fluent Multiphase Model and how are they related?
- How do I use porous media in a multiphase flow?
- ANSYS Fluent: Describing Cavitation in a Centrifugal Pump
- Hydrodynamics and Wave Impact Analysis
