May 25, 2023 at 7:29 am
FAQ
ParticipantSavant uses an Azimuth/Elevation angle convention, but if you want to plot the Phi and Theta gain components you can do that following these steps: -> Select analysis results under the label “Results” in Project tree menu (usually on the left side of Savant GUI); -> Click on “Plot” icon in analysis property panel; -> Select Decibel from Scale options; -> Select Vertical (for Theta Gain component) or Horizontal (for Phi Gain component) from Polarization options. For further information about polarization options please refer to Savant Help page (Help -> Help Contents…).
- How do I calculate inductance and resistance of a coil in post-processing phase?
- How to import/export an Ansys Maxwell model in Workbench?
- How to enable GPU acceleration in Electronics Desktop?
- How to fix messed up Windows layout?
- How to create and manage a queue of simulations?
- What are the available boundary conditions in Maxwell?
- Electric Motor Design Using Ansys Motor-CAD – Part 1
- Are solid losses and eddy losses the same in Maxwell?
- How to calculate capacitance and inductance in Maxwell Transient solver?
- How to perform a material sweep?
