April 13, 2023 at 7:32 am
SolutionParticipantSolution 2056547 presents how to display a scatter plot of two Fluent variables available in a solution file using ANSYS EnSight. Main point is to use the query over time/distance and select a scalar as sampling option. Such choice allows one to consider a portion or the whole computational domain depending on the scalar value range. Please see attached document for details.
1. 2056547.pdf
- Skewness in ANSYS Meshing
