Tagged: 17, General, mechanical, structural-mechanics, Structural/ General
August 25, 2023 at 12:16 pm
SolutionParticipantYou can use a point mass as described in the attached pdf and shown in an example project archive.
1. 2044717.pdf
2. 2044717.zip
