Tagged: 17, fluent, fluid-dynamics, MP - Free Surface Flow, multiphase, Other
January 25, 2023 at 7:17 am
FAQ
ParticipantArea and volume of the liquid in the VOF model can be calculated. Surface area 1.Create a surface for VOF = 0.5 Postprocessing -> Create -> Iso-Surface, create a Surface Of Constant Phase, Volume Fraction, and Iso Value of 0.5 2.Run a Surface Integrals Report “Area” on the iso surface to calculate the area of the interface. Volume Run a Volume Integrals Report for all fluid areasusing filed variable as Volume Fraction. This will give the volume of the respected phase. Note: For a 2D analysis, please note that it will be calculated with a depth of 1m.
- Solver message during DPM calculation: “number of stepsize underflows during particle integration step is x”. What does it mean and how to get rid of it?
- ANSYS Fluent – Eulerian & Mixture Multiphase Models & Applications – Tips and Tricks
- What is the difference between the VOF model and the Eulerian model?
- ANSYS Fluent: Efficient Modeling of Spray Breakup using VOF-to-DPM Transition
- Mixing Tank Modeling in ANSYS Fluent
- What is the superficial velocity in multiphase flows?
- Hydrodynamics and Wave Impact Analysis
- ANSYS Fluent: Describing Cavitation in a Centrifugal Pump
- How do I use porous media in a multiphase flow?
- What is the meaning of VOF courant number and Global courant number in ANSYS Fluent Multiphase Model and how are they related?
