March 17, 2023 at 8:58 am
FAQParticipantThe following will return the last part id. So if this command is issued immediately after the part is created, you will be able to retrieve the part id for that part. lastpartid = max(ensight.objs.core.PARTS).PARTNUMBER
- Rocky GPU Buying Guide
- Skewness in ANSYS Meshing
