Tagged: 2019 R1, fluid-dynamics, General, icem-cfd, Solver output
April 13, 2023 at 7:32 am
SolutionParticipantWorkbench meshing does not have plot3d export functions, but ICEM is able to perform plot3d exports. Once you have created your mesh in Workbench meshing, you can connect an ICEM component to the Workbench Meshing cell and export plot3d from ICEM. Please consult the attached documents for the details of the ICEM export
1. 2058484.pdf
- Rocky GPU Buying Guide
- Skewness in ANSYS Meshing
