How can I easily access to my last opened 20 projects without using windows explorer to look for the path and declare it?
Tagged: 18, General, Other, Project Schematic, structural-mechanics, workbench platform
June 5, 2023 at 7:04 am
FAQParticipantIn Workbench Project Interface, go to: Tools>Options>Appearance, scroll down the bar, and edit Number of “Files in Recently Used File LIst” to be 20. Now, in the same interface, go to Workbench >> Files and at the bottom part of the dialog box, user will be able to select among last 20 opened projects (No need to be saved once).
