How can I display duplicated instances of a single angular sector in a post-treatment visualization?
Tagged: 10.2, ensight, fluid-dynamics, General, Visualize Data
April 13, 2023 at 7:32 am
SolutionParticipantSolution 2056453 presents how to display duplicated instances of a single angular sector using ANSYS Ensight. Main point is to use the frame menu and allow computational symmetry to display duplicated geometry. Once the duplicated instances are created, they can be used to generate any kind of post-treatment visualization. See attached document for more details. Keywords: mirror, rotation, symmetry
1. 2056543.pdf
- Skewness in ANSYS Meshing
