Tagged: 18.2, General, mechanical, structural-mechanics
April 5, 2023 at 2:32 pm
FAQParticipantRight mouse pick in the graphics area and in the pop-up menu pick “Select Mesh by ID (M)…” Type in the node number and pick select. Pick the info icon in the toolbar (i with an arrow) to open the Selection Information window. It will show the name of that part containing the node in the last column.
