Tagged: 12, fluent, fluent-post-processing, fluid-dynamics
June 5, 2023 at 7:05 am
FAQParticipantUsing X, Y, Z-axes, Radial Coordinates etc., it is easy to create an Iso-surface. However, for a region that has a slope, creating an Iso-surface using the standard methods is not in the manuals. For an inclined region, use the following procedure: 1.Select the cell zone 2.Set the central axis 3.Return to the Iso-surface panel, use Radial Coordinates to create an Iso-surface
- Skewness in ANSYS Meshing
