Tagged: 19.1, fluent, fluid-dynamics, General - FLUENT
April 5, 2023 at 2:32 pmFAQParticipant
First the residuals must be stored to a file. There are two ways to do this: 1) Using Scheme as described in KM 2039885 2) Using a transcript For the second option, use ‘File->Write->’Start Transcript’, then run the case, then ‘File->Write->Stop Transcript’. This will create a standard text file of the TUI output, you can delete all lines but the residual printing, then read this into excel or another tool and compute the statistics there.
- Skewness in ANSYS Meshing
- How can I select interior faces and other entities that are inside the model?
- Error: Update failed for the Mesh component in Fluid Flow (Fluent). Error updating cell Mesh in system Fluid Flow (Fluent). View the messages in the Meshing editor for more details.
