- All Categories
- Fluids - Postprocessing
- How can I calculate area of wetted surface for a VOF-simulation?
February 28, 2022 at 8:44 pm
FAQParticipantIn Adapt, you can create an adaption register marking cells that have a volume fraction of one phase between 0 and 0.5. Therefore, the iso-min value should be 0 and the iso-max value should be 0.5. With this adaption register, which will be created when you have clicked on “Save”, the wall-zones can be separated. Under mesh/separate/faces, the register can be selected (option: mark). For the separated (wetted) surface, the area-integral can be calculated via Report/Results Reports/Surface Integral.
- ANSYS Fluent: Scene and Animation Creation
- ANSYS EnSight: Overview of Postprocessing a Fluent Case in EnSight
- ANSYS Fluent: Simulation of a Rotating Propeller – Part 2
- Display Multiple Plots in the Same Scene using Overlays in Fluent
- Use Different Modes for Saving Pictures in Fluent
- Creating a User Surface in ANSYS CFD Post-processing
- How can I hide the legend or colormap for a Fluent plot?
- How do I automatically export figures generated in CFD-Post from Workbench?
- Add Annotation to Graphics Display within Fluent
- How do I display a vector or contour and the mesh lines together via TUI command?
