April 5, 2023 at 2:32 pm
FAQ
ParticipantIf you add the following lines to your $HOME/.ssh/config file: Host * ForwardX11 yes StrictHostKeyChecking no LogLevel quiet PasswordAuthentication no you cal login or execute commands on remote machines, e.g. like ssh remote_machine ssh remote_machine ls without entering a password.
- Q: How do I set the license server from my client machine?
- Failover feature ‘Discovery – Level 1’ is not available
