January 25, 2023 at 7:17 am
FAQParticipantThe impact angle of which a particle hits a wall is calculated by Fluent but not stored. To get access to this you will need to write a small UDF. In the UDF the angle can be accessed using the macro DEFINE_DPM_EROSION (called every time a particle hits a reflecting boundary) or be calculated inside the macro DEFINE_DPM_BC (called every time a particle hits a boundary (except symmetry or periodic boundary)). Inside one of these macros you can either directly write the information to a file or store in a particle user variable to be printed in another function. For an example on how to calculate the angle please take a look at the customization manual in section 2.5.1. DEFINE_DPM_BC. Alternatively the cosine of the angle is given by cos_a = NV_DOT(A,V)/(NV_MAG(A)*NV_MAG(V)) where A is the boundary face area and V the particle velocity vector. The angle is then alpha = acos(cos_a)
- ANSYS Fluent – Eulerian & Mixture Multiphase Models & Applications – Tips and Tricks
- Solver message during DPM calculation: “number of stepsize underflows during particle integration step is x”. What does it mean and how to get rid of it?
- What is the difference between the VOF model and the Eulerian model?
- ANSYS Fluent: Efficient Modeling of Spray Breakup using VOF-to-DPM Transition
- Guidelines for Courant Number for steady and transient simulation.
- Mixing Tank Modeling in ANSYS Fluent
- What is the meaning of VOF courant number and Global courant number in ANSYS Fluent Multiphase Model and how are they related?
- How do I use porous media in a multiphase flow?
- What is the superficial velocity in multiphase flows?
- ANSYS Fluent: Describing Cavitation in a Centrifugal Pump
