April 5, 2023 at 2:31 pm
FAQ
ParticipantThe procedure is slightly different for a customer as compared to a channel partner: Channel Partner: CP’s should submit activities/orders in Siebel and they should be familiar with the process. In they aren’t, they should contact their customer relations co-ordinator (CRC). These request are then approved by business operations. Customer: The customers should be directed to contact their Sales Representatives.
