April 4, 2024 at 8:30 am
Watch & LearnParticipantHistory Tracking (Previously Block Recording) is an interesting tool, that can be used for replaying operations or workflows after a CAD update or in parametric scenarios. Modeling and/or physics changes are recorded in script blocks. As you perform operations, they are recorded in steps, with each step representing a script block that can be used to recreate that part of your workflow.
The video illustrates how you can use this feature.
Note: History Tracking is available when you are in the Model, Explore, and Refine stages. It is not available:
in the Refine stage, when using multiple simulations,
when multiple window tabs are open,
when using the Script Editor.
For additional information, please refer to the documentation: History Tracking
- Discovery Downloads
- Ansys Discovery – Supported File Formats
- Release Notes- Previous versions
- Importing an Autodesk Fusion 360 Design Study into Ansys Discovery
- Ansys Discovery: Transient Simulation
- Top New Features in Ansys Discovery 2026 R1
- Ansys Discovery: Creating Custom Shortcuts
- Ansys Discovery: Customizing the Ribbon Tab
- Discovery SpaceClaim – Scripting examples
- Ansys Discovery 2025 R1 Capabilities chart
