July 19, 2024 at 11:10 am
SolutionParticipantAnsys Discovery 2024R2 introduces a new feature that assists in hiding and showing faces, aiding in the manipulation of complex geometries by allowing easy editing of internal features.
Users can generate Saved Scenes with hidden faces and revisiting the configurations whenever required. You can access this feature from Display Tab under the Visibility group. Hide Faces is activated once you make face selection and allows to hide the selected faces.
If you select a face and then click on Show Faces, it incrementally shows the faces. Otherwise, it shows all the hidden faces in one click.
- Discovery Downloads
- Ansys Discovery – Supported File Formats
- Release Notes- Previous versions
- Importing an Autodesk Fusion 360 Design Study into Ansys Discovery
- Ansys Discovery: Transient Simulation
- Top New Features in Ansys Discovery 2026 R1
- Ansys Discovery: Creating Custom Shortcuts
- Ansys Discovery: Customizing the Ribbon Tab
- Discovery SpaceClaim – Scripting examples
- Ansys Discovery 2025 R1 Capabilities chart
