HFSS において、放射源と一部の散乱体を IE Region に、残りの散乱体を SBR+ に設定すると、次のような Error が出ました。対処方法を教えてください。 [error] Solving adaptive frequency …, process hf3d error: Error in using SBR+ region: Each source region should contain at least one excitation.
Tagged: 2021 R2, Analysis (HFSS), hfss, HFSS-IE (Integral Equations)
January 31, 2023 at 9:25 am FAQParticipant FAQParticipantIE Region と SBR+ を併用する場合、各 IE Region には少なくとも一つ以上の放射源が必要です。 放射源も IE Region に指定されているなら、IE Region に指定した散乱体をまとめて一つの IE Region にネーミングしてください。
- [info] Failed to delete temporary files on server ‘localhost’. Found File ~ . You may want to manually delete directory ‘~’.
- [error] Solving adaptive frequency …, process hf3d error: Matrix solver exception: file I/O failure.
- [error] Doing Multiple Region Initial Mesh Assembly, process mesh3d : Unexpected internal software error. Please contact Ansys technical support
- [info] Normal completion of simulation on server: Local Machine.
- MPI 分散計算が行えない場合のチェック項目
- 一台の PC に複数の NIC (Network Interface Card) が有効な場合の Intel MPI の必要設定について
- [warning] For magnetic materials it is recommended to solve for at least 5 inductance passes.
- [info] Failed to start next variation. Analysis will stop when all running variations are finished.
- [info] A variation (変数条件) has been requested using the following machines: Local Machine
 You are navigating away from the AIS Discovery experience
