Tagged: 17.2, fluent, fluid-dynamics, MP - Eulerian MP Flow, multiphase, phase-change
March 17, 2023 at 1:11 pm
SolutionParticipantQuestion: ANSYS Fluent offers two different approaches to describe the volume fraction (vof) transport equation for multiphase models: implicit and explicit. When considering mass transfer, is there a difference with respect to accuracy for these two formulations? Solution: Yes, using default settings there can be a difference if the mass transfer depends on solution variables (e.g. concentration). By default, Fluent solves the vof transport equation only once at the beginning of a time step for the explicit formulation. For the implicit formulation vof is solved every iteration. You can force that Fluent solves vof every iteration for the explicit formulation from the multiphase panel > expert. Then the results of both formulations should be identical, given a sufficiently small time step size and a well converged solution within each time step. Please refer to the attached document for additional details.
1. 2046040.pdf
- ANSYS Fluent – Eulerian & Mixture Multiphase Models & Applications – Tips and Tricks
- Solver message during DPM calculation: “number of stepsize underflows during particle integration step is x”. What does it mean and how to get rid of it?
- What is the difference between the VOF model and the Eulerian model?
- ANSYS Fluent: Efficient Modeling of Spray Breakup using VOF-to-DPM Transition
- Guidelines for Courant Number for steady and transient simulation.
- Mixing Tank Modeling in ANSYS Fluent
- What is the meaning of VOF courant number and Global courant number in ANSYS Fluent Multiphase Model and how are they related?
- How do I use porous media in a multiphase flow?
- What is the superficial velocity in multiphase flows?
- ANSYS Fluent: Describing Cavitation in a Centrifugal Pump
