Gerber is less conservative than Goodman, but its resulted life is less than life with respect to Goodman, why?
June 5, 2023 at 7:05 am
FAQ
ParticipantGoodman is more conservative than Gerber if the material undergoes tensile stress, however, the Gerber theory incorrectly predicts a harmful effect of compressive mean stress. If you plot directional stress at areas with min life cycles, you will find those areas experiencing compressive stress. That’s why the Gerber theory predicts different min life from the Goodman and Soderberg theory.
- Does ECAD trace mapping support more than one type of trace material (usually copper) in the same layer?
- How can I understand Beam Probe results?
- ANSYS Mechanical: Fatigue Crack Growth Analysis using SMART Crack Growth
