From the command help about D, the enforced motion and residual vector cannot be used together in a modal analysis. Is this true?
April 5, 2023 at 2:33 pm
FAQParticipantFrom the help, “D,,,SUPPORT” is needed only when rigid body modes are present because we need to apply pseudo-constraint to compute residual vector. The model is constrained when the enforced base identifier is applied otherwise. Enforced motion and residual vector are supported in a modal analysis.
