Force reaction probe on a surface shows reactions in directions that are not constrained. Why does this happen?
Tagged: 17.2, General, mechanical, structural-mechanics
June 5, 2023 at 7:04 am
FAQParticipantIf the probed surface shares topology (like an edge) with another surface that has constraints in different directions, the reactions can be pass through because the surfaces shares common nodes. It is expected behavior.
