For an independent component, why changing any dimensions of bodies in it affects all other instances?
March 17, 2023 at 8:59 am
FAQ
ParticipantThis is because the independent status is not propagated down through the structure. So when you make a component independent, the component level operations became independent. But if you make the bodies independent, the status propagates up till component and it does not affect other instances
