- All Categories
- Fluids - Postprocessing
- Fluid Flow Through a Y Duct: Solution Analysis in ANSYS Student
Tagged: ansys-student, results, Solution convergence, Y duct
June 6, 2022 at 8:45 am
Watch & LearnParticipantIn this video, you will learn how to quantify and analyze solution variables for a y-duct. You will learn how to review the residuals, calculate the mass flow and heat transfer rates, calculate the average temperature and velocity at the outlet and generate contour plots of temperature and velocity on a midplane. For any questions and support, join the ANSYS Student Community: https://studentcommunity.ansys.com/
- ANSYS Fluent: Scene and Animation Creation
- ANSYS EnSight: Overview of Postprocessing a Fluent Case in EnSight
- ANSYS Fluent: Simulation of a Rotating Propeller – Part 2
- Display Multiple Plots in the Same Scene using Overlays in Fluent
- Use Different Modes for Saving Pictures in Fluent
- Creating a User Surface in ANSYS CFD Post-processing
- How can I hide the legend or colormap for a Fluent plot?
- How do I automatically export figures generated in CFD-Post from Workbench?
- Add Annotation to Graphics Display within Fluent
- How do I display a vector or contour and the mesh lines together via TUI command?
