September 26, 2022 at 9:59 am
SolutionParticipantProblem: When Discovery AIM is launched, the standard inbuilt templates (Structural, Fluid Flow, thermal, etc.) don’t appear. The Extensions log file shows several errors.
Cause: This is most likely a Locale issue. Although you may think you have set one of the language correctly in the “Region and Language” Settings page, you must adjust the “Administrative language settings”.
Recommended solution:
1. From the Windows search, enter Region, and click on the “Region & Language Settings” result.
2. Click on the “Administrative Language Settings”
If “Administrative Language Settings” option is not visible, click “Additional date, time, & regional settings.
3. In Regions panel, select “Formats” tab. From the Format dropdown list, select the language that was set in “Region and Language” Settings page.
4. Save the changes and close all panels.
5. Run Discovery AIM.
- Discovery Live: How to change units
- Discovery AIM tutorial – Analysis of cantilever beam with I cross-section
- Discovery AIM – Scaling deformation contour results
- Discovery AIM tutorial – Structural Analysis of Plate with Hole
- Discovery SpaceClaim: Getting Started Tutorials
- Creating a Helical Geometry in SpaceClaim
- How to setup a Parameter Study
- Convert 2D Drawings to 3D Models in Minutes with SpaceClaim
- Discovery AIM tutorial – Heat Conduction in a Hollow Cylinder
- Discovery AIM tutorial – Eddy Current / Magnetic Frequency Response
