September 26, 2022 at 9:53 amFAQParticipant
FAQ: Resolving issue related to special characters in server name
Problem:Â You are unable to set the client licensing server in the Client Settings Utility if hostname contains a hyphen
Recommended Solution:
This is a known issue and is resolved with the 2021R2 release.
For a workaround, you will just need to modify the ansyslmd.ini file manually to put the – back in after using the settings to add it without the hyphen.
Example: in Settings Utility, specify –  ETAAnsys
In ansyslmd.ini – modify to: ETA-Ansys
You may need to save a copy of the ansyslmd.ini to the desktop and then replace the copy in C:Program FilesAnsys IncShared FilesLicensing to avoid permissions issues.
- Ansys Discovery Hardware Requirements (2024 R2)
- What’s New in Ansys Discovery 2024 R2
- Discovery License Activation Troubleshooting
- Resolving Error “QA services environment variable is enabled” while opening Discovery products
- FAQ: Resolving Error – ANSYSLI exited or could not read server port ANSYSLI_FNE_PORT
- Discovery Subscription license – Command line options
- Discovery Family Licensing & Installation
- ANSYS Discovery: Compatibility Utility
- January 2023 Subscription Licensing Issue
- Discovery: Black screen with no geometry appears after launching Discovery
