September 26, 2022 at 9:59 am
FAQParticipantFAQ: Resolving issue related to renaming bodies using F2 shortcut key
Problem: In SpaceClaim 2021 R1 version, objects in Structure tree cannot be renamed using F2 shortcut key
Cause: This was an accidental change which has been fixed in next version (2021 R2)
Recommended solution: In SpaceClaim 2021 R1 version, you can use shortcut key Shift+F2 or Alt+F2 for renaming objects.
- Discovery Live: How to change units
- Discovery AIM tutorial – Analysis of cantilever beam with I cross-section
- Discovery AIM – Scaling deformation contour results
- Discovery AIM tutorial – Structural Analysis of Plate with Hole
- Discovery SpaceClaim: Getting Started Tutorials
- How to setup a Parameter Study
- Creating a Helical Geometry in SpaceClaim
- Convert 2D Drawings to 3D Models in Minutes with SpaceClaim
- Discovery AIM tutorial – Eddy Current / Magnetic Frequency Response
- Discovery AIM tutorial – Heat Conduction in a Hollow Cylinder
